Mando helmet assembled
Continuing the discussion from Best Adhesive for PLA?:
I used CA glue to hold the parts together and then used a soldering iron to melt/weld the joints together on the inside AND I only managed to glue myself to the helmet twice :crazy_face:
Now for the hard part… smoothing and finishing
Oh wow, are you going to paint it as well??? Would love to see the finished product :slight_smile:
I do plan on painting it but I haven’t decided if I want to go with a custom design or make it the same as the TV series.
Check out a YouTube channel called “Frankly Built”. Frank has done a bunch of different Mando buckets with a bunch of different finishes (the graphite rub is my personal fave). Might give you some inspiration!
How to Paint a Mandalorian Helmet - A Guide to Painting and Finishing - YouTube
@SpaceMoose Thanks for the tip, I’ll check it out
My pleasure! BTW which STL did you use for that?
I used this one
https://www.myminifactory.com/object/3d-print-mandalorian-helmet-v2-106137
Got the paint on finally
Looks Awesome !!! Great Paint job . What are you going to use for the visor glass ?
