Does anyone know if I can use the Micro Swiss NG Direct Drive on my Thinker S? I know I will have to switch out the fans with my stock fans as the board is set up for 5v fans. My Thinker S v2 has a Nema 17 stepper motor.
Will I be able to use the motor that comes with the NG?
What additional things will I need to do to use it?
I’m new to 3D printing, so detailed advice would be greatly appreciated.
Welcome to the forum, Glad you found us. nice to see you.
Although I cannot comment directly if it will mount to your Thinker I can tell you that the NG comes with a stepper motor and fan shroud. Should be all the parts you need. You just need to make sure your end stops will switch up without an issue.
Yes, it’s compatible, It’s also a Nema 17, Worst case is you may have to repin it if it runs in the wrong direction but 90% of printers are good. The major part is you will need to update the e-steps when the installation is complete. You can do this through Pronterface using the M92 command.
If you are able to connect Pronterface before you do the install and verify the version of Marlin installed. Just to confirm you can update the required parameters? The only other change you may have to make is the M851 for the BLtouch offset if equipped.
