Yesterday I was doing a 9HR print and while doing a random check I found the print stopped. This was at the 7 HR mark, possible just to piss me off. The printer was still on, the filament on the tip had fused to the print and had to be broken off and I hit the pause button and turned it back on. It followed the proper routine for that by parking it self and when started again it came back to the model and started to run again at the point that it stopped at except it just ran around the same track over and over without printing. At that point I turned the machine off and turn it on again, then I tried running all the steppers X Z & Z + the extruder manually and they all worked fine. Also the printer would home when properly. This morning I tried a test cube to see if the printer would work and it made a perfect print (Insert head scratching here). After that I started the print that failed a second time and at this point it is still going fine.
I have know idea why it just stopped. Maybe a power blip, but it should have returned to the print on start up and continued.
Any ideas?
