My research in 3d printed animatronic
     Making zbrush skin for digital animatronic, 3d printed with FDM and Resin , 6 servos total, 3 servos inside head 3 gimbal .lids and teeth resin printed. #3dprinting, Sketchup design and sculpted in zbrush ,my research of reverse engineering into a digital animatronic process and my resin printer is 90mm wide because of build platform sculpt printed flat.   round plate concept digital core blockout design . I Designed the animatronic , made digital core to sculpt on in Zbrush, Molding box for sculpt and using silicone and after curing removed from mold and a mold release was added to the mold,  pour skin silicone into the mold and place core into the mold socket, Which this gave me a skin thickness to fit animatronic skull prefect.
more info here Gary Willett (@willett.gary) • Instagram photos and videos
https://www.youtube.com/watch?v=7WY9Zf0g2l4
Very impressive - a bit creepy when you watch the video but nicely done.
Very cool. I have a friend that collected (pre pandemic had to sell them sadly) antique clockwork animatronics. Very interesting!
To skin this one looking for the resin build platforn
https://www.instagram.com/p/CvD6It4Opaw/?img_index=1
Nice. Is there a clearer version of the video?
new channel https://www.youtube.com/@garywillett4146
old account https://www.youtube.com/@willettfx
Very impressive. Did you do all the design by yourself?
Yes Design all
Like I said very impressive. I’m into robots and animatronics but since my design skills suck I started to copy and printing the Inmoov robot by Gael Langevin.
https://www.instagram.com/p/Cu0s9o6uAaM/?img_index=1
https://www.instagram.com/p/Cs5Q9CYuAYr/?img_index=1
Go with servos and rc radio and go servo controllers and then motors https://www.servocity.com/servos/ and https://www.motionrc.com/collections/servos?filters[brand][0]=Freewing&filters[custom_fields.Gear_Type][0]=Metal
There is a different in cheap servos under $10 don’t buy . metal gears ,high torque . Gary Willett on Instagram: "My testing and Research is to show micro/mini servos torque for future animatronic projects ,being small servos will help in designing , having smaller animatronics to having more space to work with. #animatronics #kingmaxservos KingMax CLS02MP--18g 5.8kg.cm,digital,waterproof metal gears mini servos Item:CLS02MP Gear:Full metal Spline:Standard 25T Motor:Coreless motor Bearing:2BB Dead band:2μs default Waterproof:Yes Operating Voltage:DC5.0~8.4V Rated working voltage:DC 7.4V Working frequency:1520μs/330hz Working angle:±63°@800us-2200us Working temperature:-10℃~+50℃ Storage temperature:-20℃~+60℃ -- High performance digital mini servo -- High-precision metal gears -- High quality coreless motor -- Middle CNC aluminium case -- Dual ball bearings -- Waterproof SPECIFICATIONS: Operating Speed(5.0V):0.19sec/60 degrees Operating Speed(6.0V):0.15sec/60 degrees operating Speed(7.4V):0.12sec/60 degrees Operating Speed(8.4V):0.10sec/60 degrees CLS02MP Stall Torque(5.0V):4.00kg.cm (55.56oz/in) Stall Torque(6.0V):5.00kg.cm (69.45oz/in) Stall Torque(7.4V):5.80kg.cm (80.56oz/in) Stall Torque(8.4V):6.80kg.cm (94.45oz/in) Dimensions:22.7*12.5*26.4mm/0.88X0.48X1.02in Weight:18.3g(0.64oz) Connector Wire Length:JR300mm(11.7in)"
design servo sockets and print them
I can see you been doing this for a long time … and yes I learned the hard way about servos.
what design software do you use
I played around with Fusion 360 but did not spend enough time with it to get anything useful out of it. S
What are you using?
I use sketchup 2017 , blender , sculptris and zbrush . but sketchup is 95% of the animatronic.
