So I was getting lame prints. Lots of strings, filament dragging along the bed. Yadda-yadda-yadda.
Right off the bat I have to point out , the problem was solved by changing the nozzle. prints fine now.
However in going back and forth in the options to raise / lower extruder, feed filament, leveling the print bed : I may have inadvertenty activated/deactivated the DISEABLE STEPPER ON/OFF.
Ayone know if default setting is ON or OFF?
And what is a stepper anyways?..
And what can happen if you have not chosen the correct setting?
thanking you in advance
gondolin the noob
