Nozzle help - elegoo
Hello, I recently replaced my 0.4 printer nozzle for a 0.8 nozzle and it’s coming out wonky. Is there settings I need to change? Photos attached.
I’m not familiar with that printer but if it is a variable that you need to adjust for good prints then I would say that it needs done to match the new nozzle.
Did you calibrate the z settings after the new nozzle? You should do Z and flow rates for sure after a swap.To me it looks like a z offset issue. Clean the bed too, I like use detergent every few months and a sponge to get grunge off that just alcohol leaves behind. detergent and soap are different. Detergent doesn’t suds up and makes you skin slimy.
What is this? As kite said you need to do calibrations. If this is a storm use orcaslicer and do the flowrate test.
