I made the benchy pattern successfully that came with the printer. made a few lego outlet covers and light switch covers. all with pla. then i switched to petG and since then my printer won’t work properly. the nozzle won’t go low enough to print the inside of the lego outlets anymore and everything I’ve tried printing has messed up or broken.I have tried all the different settings for all the different potential problems but it still won’t lower the nozzle enough to print inside the designs
If the PLA is printing okay - and the issue only happens when you switch over to PETG - I would recommend taking a look at your settings you are printing at. Lets start off with the basics, what temperature settings are you printing your PETG at?
for pla i was printing at the temps on the reel, and i’ve tried all the different settings, done the z callibration, lowered the nozzle, used glue stick, and painters tape and when it gets to the middle it will stick .
