So i bought a Genuine E3D Nozzle X 0.4mm. I figured since my prusa mini uses E3d nozzles, the Nozzle X should be a simple addition with maybe a small temperature jump.
Well i bumped it from prusament pla @215 to 225 in 5° increments and it still wouldnt improve. I tried different filaments that I knew printed well just the day before and same underextrusion issue.
I double checked this nozzle had the 3 dimples which should indicate a 0.4mm nozzle. I even contacted prusa customer service and apart from my tension screw being a tadd bit loose, still not working half as well as before.
Long story short i went back to my original nozzle and the problems went away.
I know @kitedemon loves his nozzle x, which is a bit why I went and bought it over other hardened nozzles.
Im sure i could fiddle more with various settings but im not the most familiar with the values/settings in prusaslicer.
For the time being the nozzle will be waiting for me to finish rebuilding my other printer which ill try harder at hammering out what i need to make use of the nozzle x
So does anyone have any success stories with the nozzle x and have any recommendations?
Here is the underextrusion.
