Printer maintenance
HI, I have had my Creality Ender 3, V2 for about 6 months and have run about 3 and a half reels of PLA filament thru it, mostly successful, some not so much. I am now hearing very slight rubbing noises when it is running so my thoughts turn to regular maintenance. What should be done to a printer on a regular basis to maintain it. Any ideas?
Geff
I use a dab of lube on smooth rods. Clean the dust and junk from anywhere I can find it. I also check the alignment of idlers, belt tensioner and make sure the crews and such have not backed off. Sometimes I take the hot end apart and make sure it is clean, usually only if quality dropped. New nozzle.
3 Reels in 6 months is very light usage. I’m on my 12th reel in just under 4 months, for comparison.
For lubrication, I followed the hive mind’s recommendation: https://www.amazon.ca/Super-Lube-51010-Precision-Oiler/dp/B000BXOGHY/ref=pd_bxgy_img_2/132-1314353-1623741?_encoding=UTF8&pd_rd_i=B000BXOGHY&pd_rd_r=fe04c3b7-fd6d-4e43-abc0-6fd63eb764ae&pd_rd_w=WnRyG&pd_rd_wg=RtirR&pf_rd_p=42339929-297e-4141-b7b2-fe55db70f4b7&pf_rd_r=P8C0SX336B402H8QH5F8&psc=1&refRID=P8C0SX336B402H8QH5F8
Aside from squeeking, the only maintenance issue I’ve had is a buildup of dust and hairs, particularly on the rollers. The Rollers themselves will need to be tightened once in a while using the eccentric nuts because they will physically wear down and get smaller.
I’ve had to replace one Bowden tube because of a clog. The magnetic build plate is the only other thing I’ve had to replace.
