Printers not extruding
My ender 3 neo is not pushing the filament into the nozzel when printing (I have cleaned the nozzel)it also works when changeing filament any sugestions
What filament are you using? PLA , PETG or ABS? Try to increase your hotend temp to 5-10C up to the max temp required for your filament.
Have you tried to check your extruder? Maybe you need to clean it or adjust the extruder gears.
:grinning:thanks ill try that
did not work
could it be heat creep? Check the cooling fans are working and at a reasonable speed.
If that doesn’t work change the nozzle it looks crusty, they are consumable items. and when it is apart check the heat break is clear. I really like the cleaning rods for that. Check the liner if it has one and clean and adjust the extruder gears.
I agree with @kitedemon. Brass nozzle usually last around 1-3months if used almost every day depending on the filament(PLA, PETG, ABS, etc.).
