TPU has been widely used in 3d printing to achieve rubber-like parts. The challenge with TPU is that its soft and its as if you are trying to push cooked spaghetti noodles down your hotend which poses many challenges.
What are your best tips and tricks for printing with TPU?
What print temperatures are you seeing as a good range for TPU?
What bed surface did you find works best with printing in TPU?
as with anything new, SLOW, I can get TPU to print with a Bowden tube but you have to print even slower.
I have 2 machines that I will print TPU on regularly, one has a micro Swiss direct drive and the other has another style direct drive. both will print TPU quite well but don’t push it anything above 25mm/sec or I know I’m playing with failure. May take a little longer but the outcomes are amazing
there might be a micro Swiss all metal direct drive hot end kit in the making it’s not 100% sure yet but there’s been some talks. I’ll have to agree with Jason you can definitely print TPU on that machine you just need to print between 25 and 40 mm a second don’t retract over 3.8 or it’ll probably spit out the side of the extruder. Also there is a file on thingiverse to go in between to create a zero space Gap
yeah, mine already has this style too. For me, as long as I kept the heat up, like 220C, and the speed slow it worked fine, but if I pushed the speed with lower temp, it would bulge out at the drive gear.
where the gears push the filament in through that hole if there’s any space there the TPU can spit out the side so there’s a print on thingiverse to fix that
I use a flexion extruder it works good and uses a dial that works like a “cam shaft” as people have said that you can turn and set it for tpu,pla,abs,and soft filaments, I print very very slow and use sainsmart tpu a glass bed with purple glue stick on the bed, hope this post helps or gets someone thinking
Yes speed is a big deal but there can also be an issues that some may find it difficult to address. Even with a direct drive, correct speed, temp and retraction you may find your extruder clicking and miss feeding. It can be frustrating but too much pressure at the drive gears of your extruder can cause feed issues, especially with soft materials. Running Filaflex 70A and too much pressure can cause the filament to pull or deform out of alignment jamming between the gears and the extruder casting. Move slow and with less pressure can provide great results.
Yes I’ve heard of fast speed tpu and good extruder setups, my one friend prints tpu at 12mm/s (slow very very slow) and my other friend prints at 100mm/s (pretty fast in my opinion) by the way I print at 20mm/s for sainsmart tpu and speed 50 in on machine settings.
all my TPU Prints on both my machines print at 100 mm the only stuff I print slow is like 82a and 70a, but I also have machines that are designed to print fast my Ender is not even an Ender anymore so it helps when you have the right gear and then the right tune on your printer I don’t use Marlin base firmware’s either I use duet and klipper so much better than Marlin and they, have settings where you can tweak for speeds. also find what frequency my printer is hitting how many hertz so you can tune out ringing and stuff like that at high speeds
