Hello,
I am a beginner in 3d printing with an Alfawise U30.
The printer is assembled and seems to work.
I have installed Cura to have Gcode files from stl files with the Alfawise U30 profile.
I tried to print little objects but I have always the same problem : the first layer is bad, no details appeared.
So, to have a reference, I got 3dBenchy stl file and generated a Gcode file with Cura.
And like the other tests, the first layer is bad.
And then, I wondered if maybe the problem can come from the way the way Gcode is generated.
So, I made a test with the 3dBenchy Gcode file delivered with the Alfawise U30.
But I had again the same problem : the first layer is bad.
I don’t know where is the problem and I don’t have much experience, so I want to ask you if you can help me with this.
Thanks
