Is this still a thing???
I have some, are the centre diameters the same on all/most filament spools. Can I use different brands on these spools??
I have used them on 3DPC refill rolls and Unveil. My cousin has used them on Jayo and Overture refill rolls without issue.
OK, thanks.
You sure can!
Here’s all of our refills available on the 3DPC store
Most brands have adopted the same dimensions as Bambu’s spools for that inside core so you’ll be able to use a variety of refills with them.
All refills sold on our site will be compatible with Bambu Spools, including:
If you’re looking for alternatives to Bambu’s spool, R3D Bambu Compatible Reusable Master Spool is also sold in our shop. It has a higher temp resistance (~90C), AMS compatible, and a bit cheaper too.
Or you could 3D print your own!
(PETG or better recommended).
Cheers,
Spencer
— 3D Printing Canada, Media Team
