I have had a touch screen die and looking to replace.
The original has a 40 pin ribbon cable that clamps on the back while the new one has 40 pins ( 2x20).
The ribbon cable is a bare end, no connector.
Is there an adapter for this?
I am a bit confused by your post. A picture of the new and old would help.
Ribbon cables are usually sold as just a cable the ends are bought separately. The manufacturer of the printer likely sells the correct cable as a single unit as well.
Photo’s in order.
Old Screen Ribbon c
Do not know enough on connectors as to what can/cannot be done.
Thanks.
It’s a bit hard to judge from the photos, but is this basically the animal?:
https://www.adafruit.com/?q=flex+cable+40+pin&sort=BestMatch
There are other lengths available.
Thanks People.
Looks like you have laid my fears to rest and that it may be a minor upgrade than a major one.
if its made I am sure there is an adapter for it. We don’t carry it at the store but I am sure something is out there.
Is this a change that you think would be common? in other words should I source an adapter to carry in store?
Thanks for the inquiry but I do not think it would be required.
You guys carry quite a bit of printing peripherals but do not need to be a one stop shop.
Hey @3DMultiMaker
thanks for the cander, We do try to carry as much as we can but you are correct, there is only so much floor space.
Jason
