Setting after installing the micro swiss direct drive
Hi, what is the settings that I have to change in order to be able to print with a Higher temperature with m’y cr10 s pro? Did I make those changes with Pronterface?
If you have installed just the hot end and want to change the max temp for your printer you have to burn new firmware. Unless you can find something precompiled. I would doubt it unfortunately because you are getting into machine settings.
If you have installed the direct drive as well you will have to update the M92 through pronterface or the console if you are lucky enough to have that value in the screen firmware.
Hi again Jason, I found a firmware with the 300 celcius setting on it. Everything work verry well, I’m totally satisfied. Thanks!!!
that’s awesome, thanks for letting us know.
