Tarantula board upgrade V2
Is the start
Is the Mks Gen L V2.1
Board is hooked up to the 2nd Lcd (original Lcd doesn’t work with the V2 board).
Turned on power, board lights up, fan comes on, Try to move X,Y.Z steppers… nothing.
Can turn on extruders, hot bed and control part fan.
I bought the board on Amazon.
amazon.ca/gp/product/B07RRXK5TV/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
What I Understood is basic drivers are already built in, and is setup for stepper upgrading!!!
Do I need to get drivers?
If So, Any suggestion as to which ones!!!
Original Tevo stepper motors.
Bill
Hi Bill
Yes, your drivers are missing from the board, You will need to buy 1 driver for each axis motor you want to drive.
They will plug in down the left side of your pic. Ensure you power off the printer before you install them and triple-check the orientation before you power it up. If they are backward you will pop the driver, Board or both.
You may have misunderstood, I think the basic firmware is built into the board not the steppers. On these styles of boards, the drivers are always additional.
I ASSumed the there were Basic drivers Installed and the plugs were for Upgrading.
Couldn’t read anything (on the Amazon page) that indicated the board needed them… Or not lol
Thank You!!!
I have 5 A4988 drivers coming Saturday.
Do I need to edit the firmware?
I would assume on some level you will have to build new firmware, At least to set the bed size and max temp parameters, The basic firmware that comes on it is just to allow you to test base functionality, End stops, Heaters and the such. Mechanics are going to be unique for almost every printer. Ender 3 and Ender 5 are very different-looking printers. Ender 3 is a rep-rap cartesian and 5 is a cartesian. However, their firmware is almost exactly the same except for the fact the Z axis is backward on the 5 and forwards on the 3.
Yes I have to edit the firmware!!!
Not sure if I have to identify the stepper drivers in the firmware
I’m upgrading to dual extruder/large bed 220X300X240mm… I’m Hoping!!!
I have the large bed plate (200X280) plate is 220X280, I have a glass plate is 220X300.
I measured how high the Z axis goes Without binding, 240 Should work!
I just have to figure Where to edit the firmware and Ultimate Cura so I can use the Full surface area of the bed (glass). I Know I can’t use Every mm, but close!
Have the Y and the Z figured, Not sure what to set X offset to.
I have done 2 dual colours, but with X reduced to less then 200mm.
Cura shows a shadow of unusable bed no matter how I size it.
yes, you will have to identify the steppers on each axis.
Usually, the shadow is because of the skirt setting in the slicer, if you set the skirt at 10mm space you lose 20 mm of the printable area on the bed.
Sounds like you are well under way
Found it (steppers)
I found the Shadow lol
I set the E0 X offset to -17.8mm and E1 offset to 0 in Ultimate Cura 5.1.1
I think I’m suppose to set the offset in the firmware.
And this should be another thread… Right???
Thank You
I set the offset in the firmware . . . . It looks like it’s Working.
A little fine tuning and the Usual Adjustments!!!
Thank You :smile: :smile: :smile: :smile: :smile:
Hi, @Bill_L Glad you got it. I try to start a new thread once we have worked through one issue.
That way google finds it easier to associate problems with associated questions on the web.
Ask away, we will help you where we can.
