So I’ll try to give all the relevant info that I know, just ask if I missed any needed info.
I have an SKR Mini E3 V3 main board. I bought BTT TFT35 V3.0 screen to replace the LCD. I expected it (evidently incorrectly) to be fairly straightforward, what with both being BTT products.
I get a No Printer Attached! error when powering it on. I verified that both the printer main board and the screen were set to a baud rate 115200.
The 5 pin JST cable I have tried in both of the 5 pin plugs, but I think(please correct me if I’m wrong) that the bottom one is the correct one. The other end of said cable that goes to the main board, that has a 1 pin connector and a 4 pin connector, I have tried in all four possible configuration on the 5 pin TFT pin set on the main board. I also initially tried all four configurations on the SWD 5 pin set before I saw the TFT labeled set.
I downloaded the firmware folders from GitHub and flashed the "BIGTREE_GD_TFT35_V3.0.27.x.bin file along with the config file and the font and bmp folders to go with the hybrid red theme while I was at it. It booted up fine, and did the whole firmware flashing process, and then opened up like it should, but still had the error.
I also tried following the advice in the following attached picture, again, the firmware flash worked, but no fix. I tried crossing the TX an RX wires in case I got it wrong, but no dice.
As far the main board firmware goes, I use the custom compiler website here. Firmware Builder - Marlin Firmware Service According to the guy that runs that service, he has tested the board and screen combination I am using, and it works, so the main board firmware shouldn’t be the issue .![]()
I really hope someone here can shed some light on the whole issue, because I am running out of ideas and patience with this. Thanks!
