The Easiest Way EVER To Level The Creality K1 Bed
Hi Everyone,
I have received some requests to make a video about how I level the K1 beds, so that is exactly what I did.
Please give it a look, hopefully it can help some of you out!
Matt
Thanks Mathew that explains a lot.
Just a thought and maybe wrong but if the back one is out then why not loosen the two front ones and lower the back one down until against the stop and then adjust the two front ones. Easier then trying to get at the back one.
Yes that is a great idea, I had never considered that. I think I will start doing that from now on!
Thanks Matthew, that was a helpful video.
What is a “good” final bed level tolerance?
I have adjusts the bed on two Ki Max units to the following image levels.
How do i fine tune these?
IMG_5711
For your first bed I would check that all 4 screws on the corners of the bed are fully tightened down. Seems that all 4 corners are lifting up a bit, its possible that tightening them down may help with that. If it doesn’t help then I would move on to the method I suggest in the video.
For the second bed I would try out the method in the video first and see if it helps. The bed definitely has a slope to it meaning that more likely than not one side is lower. Let me know if it doesn’t work!
