Tips For 3D Printing Beginners
Hi everyone!
We have had a lot of new users on our platform recently, as 3D Printers are getting more affordable and easier to use the market is quickly expanding.
I want to make a thread here for you all to share some of your best tips for beginners to the 3D Printing world. It could be as simple or a complicated as you would like, lets save the new users some headaches down the road!
I want to make this into a great thread filled with useful info for new users so I would like to offer you all an incentive. I will give you all until the 14th to get your submissions in, then on that day I will have a draw for a random user who has posted in this thread to win a prize! Please don’t fill the topic up garbage to try and win the prize, I would like to test run this idea to see if it is worth doing more often in the future.
Throw in your best tips for new users, who knows maybe you will win!
Auto-levelling is being implemented on many new printers: but auto-levelling is a misnomer and some new users question the validity of the data they see. The first thing I did when setting up my C3V3SE was to literally put a level on the bed (which I found actually leaned heavily to the right). Placing shims under the right front and right rear feet were needed. Ensuring your printer is physically level first, auto-levelling works wonderfully!
First - Attitude/Approach
Depending on the printer you choose, at some point you’re going to have problems. Take a deep breath.
Get a pen and paper, or open a doc on your computer to track what you do.
Look at what your printer maker states is the problem, if they don’t have great manuals, look for others on this and other forums who have the same printer, and had similar issues.
Make notes on what they or the manufacture suggest you try do to resolve your problem.
Try the simplest things first, take notes on what if anything changed.
Take another deep breath.
Then try the next thing, taking notes.
Repeat this until you’ve either exhausted the pool of knowledge, or resolved the issue.
Don’t be afraid to ask on this or other forums for suggestions. If you get lots of negative trash talk from a forum, walk away - there are others. This is a hobby or for some, career, with an incredible range of variables to keep track of as you see to obtain the print quality and results you want.
Keeping notes will help you stay focused on solving the issue, while you really get to learn the inner workings of your printer, the firmware that drives it, the software you use to create your models, and the material science behind the filament or resin you use.
Stay calm. Remember, you’re learning - keep your expectations realistic. It takes time to master this … I’m going to go with craft here, and if you keep calm, and keep plugging away, you will.
Second - Practical Practice
Get a reasonable decent vernier caliper. They don’t take long to learn to use.
Run through the calibration tutorials, print the cube, the thermal tower, etc. It’s tedious but worth it.
Come back to them from time to time as you change filament, or after any tweaks you make to your system.
Ease into the bigger prints - start small so you can see if your settings are working as expected - Don’t try to print the Mandalorian Mask right after you figure out you seem to get good results at 215 deg C nozzle temp, 55 deg C bed temp with white PLA, and running at 40 mm/s. Murphy’s waiting.
Get to know your PLA or PLA+
Get to know how fast your individual printer can really run. Mine’s supposed to get close to 60 mm/s, I rarely run it above 40 mm/s because it gets crappy.
Make sure you have it setup so you can shut the door on it and not bother the rest of the household, but, don’t ignore it - keep tabs - they can have various levels of failure including self immolation.
Keep Practicing. Keep measuring - when things start to drift away from your best, you’ll have those documented, and you’ll have an idea what needs to be fixed (new v-wheels, new belts, etc) and what your maintenance cycle will be.
Set a max monthly spend limit while you’re learning - this can get costly.
Meet up with local 3D printer folks at your library, community center or what have you - sometimes a second pair of eyes helps!
Before you know it, you’ll be holding hundreds if not thousands of points of data about how your printer behaves under differing conditions, filament, etc. and develop the knowledge on what to tweak.
I think I would say when starting pick a good quality filament buy two maybe three rolls of the exact same and print out all of them. Learn your stock printer learn its quirks, figure out all the basics before you buy all kinds of extras, mod the printer, or do much of anything else.
My second is nozzles are a consumable item. Depending on the material they can wear out really fast. Stringing, blobs, dimensions, bed adhesion and general quality all can point to a worn nozzle. If a printer was working well and same filament is used and it kinda starts to get worse with nothing really changed try a new nozzle before you adjust everything else.
I got two first if a layer is shifting check the opposite axis & 2) use higher temperature filaments in the winter like poly carbonate co poly ester or ASA
These are some great tips everyone!
Lets keep em’ coming!
Levelling a machine by hand (aka Tramming) with gauge blocks/some conductive material and a simple LED circuit is FAR more accurate (like nearly indicator accurate) compared to using paper.
Never underestimate how much open frame machines can be messed with by humidity and ambient temperature, it’s shocking.
It NEVER makes sense to risk the machine for a print. Air on the side of caution for strange noises and unexpected behavior. “Itll probably be fine” is a saying earned by experience and paid for in downtime :wink:
Seasonal fluctuation is a real thing for some machines. Temperature towers can produce different results based on the time of year. So if the machine is misbehaving randomly months later, it’s not a bad idea to check temps.
Read the MSDS and safety tips for any exotic materials. Just because your machine can print it doesn’t mean it’s safe to coexist with it during that process, see nylon for an example of this.
Keep spare consumables for your machine including nozzles, silicone socks, heating elements, etc. Most “I hate this machine” does not come from the machine breaking, but the inability to quickly tackle the problem. Conversely, be familiar with how to clean a nozzle, and know when to replace it. If you ever catch yourself thinking “well I’ll try cleaning it again” chances are it’s time.
If you can’t remember the last time you greased rails/screws, it’s time to do so. Most hiwin-style bearings can run for long periods of time, but there’s no reason to neglect these as the only thing gained is a few cents of grease and the potential losses can be nasty.
Invest in good allen keys, they will be useful for your next 10 printers.
Never use a metal wire brush to clean an actively powered hot end. Never use a rotary wire brush to clean anything on a printer.
(Unserious) Throwing away successful benchies offends the machinegods and causes downtime.
My biggest tip for beginners is to start with simple models and learn the basics before trying complicated prints. Keep the build plate clean, make sure the first layer sticks properly, and change one setting at a time when troubleshooting. Also, don’t throw away failed prints too quickly; they’re often the best way to understand what went wrong. I’ve found it interesting to see how the same basic principles apply to prototyping work at Rapid Made, where getting the right print settings and material choice matters just as much. Patience and experimentation really do make a difference.
Printers need maintenance and periodic calibration also. Accept the fact that it will break down or fail in some manner at some point. Problems are not optional!
Calibration. I also suggest replace parts before they are totally dead. It is easier to pop in new part in when everything is still working well.
Quite common clear calibration, its in order so it is a good process, a bit tedious…
Most early failures seem to come from rushing the first layer. A boring calibration print beats chasing fancy models with a loose belt or sketchy bed level.
For anyone just getting started with 3D printing, my biggest advice is to start with simple designs and take time to understand your printer’s basic settings. Things like bed leveling, nozzle temperature, print speed, and layer height can make a big difference in print quality. Don’t get discouraged by failed prints because they are part of the learning process. It’s also worth experimenting with different materials to understand which ones work best for your projects. If you’re interested in learning more about 3D printing, rapid prototyping, and custom manufacturing, Rapidmade is a useful resource to explore. Most importantly, be patient, keep experimenting, and enjoy the process of learning!
