If you want to avoid any clogging of the extruder, I’d suggest unloading the filament at a temperature that is 20 degrees Celsius lower than the printing temperature. Doing so will soften the tip of the filament without melting it, which will prevent any dripping along the filament pathway, such as the PTFE tube or extruder gears. Hope this helps!
