I have recently put together a new troodon 2.0, and when i run a test print i am getting weird PA looking artifacts. I have tried a couple of valuse in my start gcode lines but nothing seems to help. Does any one out there who built a troodon 2.0 have any suggestions or tips?
Processing: 1000005488.heic…
Thanks Jason, i dropped by 10degrees and it looks like this. Did i drop too much? Im using overture PETG at 235 currently. I have found that cura works best with this printer, there is a nice temp tower ad on if i remember correctly, just not sure how to use it.
I was going to ask if its try, it kinda looks a bit wet and it still looks a little hot. would you consider running a temp tower on the filament just to double check the heat range on it?
If i were you, i would tune the printer to the filament you’re trying to use before trying to do actual prints with it.
I recommend you download Orca Slicer and run the calibration tests from there, you’ll be having great-looking prints in no time!
Thanks for the suggestion but im not a fan of orcha. This is weird my other troodon came fully calibrated, i was thinking this would be the same. Im putting a stealth burner with a rapido hotend and adding clipper this weekend so im not going to get this tuned too much until all this is complete.
Here is the temp towers I personally use. Michael (teaching tech) has done an awsome job on building this page for you to do an overall calibration or just pick something that may be off.
