Troodon XY stepper motor?
Good day, is this NEMA17 Stepper Motor 48mm 1.8 Degree 2.5A 5.0kg.cm 42BYGHW811 is compatible for XY axes on my Troodon ?
Stepper motor spec’s from Vivedino Troodon are :
42 stepper motor 1.8°
X axis: 48mm
Y axis: 48mm
Z axis 34mm
Extruder: 34mm
Take note that shipping from Formbot is very expensive
Thank you in advance!
LM
yes that’s the same replacement part.
It will be equivalent replacement item.
Here is the direct link
https://3dprintingcanada.com/products/nema17-stepper-motor-48mm
Just out of curiosity, did yours fail? Or did the stepper driver fail?
One way to double check is to swap the connectors from a working axis and trying that axis to move when attached to the bad stepper motor and driver.
Or are you adding a feature?
Hello, stepper motor failed. What happened is one of the stepper motor start to make noises (clic, clic, clic) and after a few print motor start to jammed randomly in XY axes.
I don’t know the life time of these stepper motor but I did print a lot since I bought this printer a year and half ago.
Hope that meet your curiosity !
Regards
LM
