I tried a print yesterday on my Creality CR M4 and got the attached print. It did not work out. The filament did not stick to the build plate instead it was loosely on top.
Sure looks like too large of a Z offset to me.
What would you recommend for a proper z-offset? The base is a disk 8” dia and 2mm thick. I don’t know what would be good or bad for setting the Z
You want the Z offset to be such that the nozzle is just above the bed. The gap should be enough that you can slide a piece of paper between the bed and nozzle with just a little friction.
