Using a portable AC near my printer in a Vermont summer — bad idea?
I have my printer set up in a spare room in Burlington, and it gets uncomfortably warm and humid in July and August. I have been thinking about adding a Shinco 10,000 BTU portable air conditioner to that room, partly for me and partly because I worry about filament and print quality in the heat. Before I spend the money, I am trying to figure out whether a portable unit makes sense in a small room like this. My concerns are the exhaust hose setup through a window, how much floor space it takes up, and whether the airflow or temperature swings could cause warping or drafts around the printer. I do not want to trade one problem for another. I came across this Shinco 10,000 BTU Portable Air Conditioner Review while reading up on the unit. Has anyone here run a portable AC in the same room as their printer, and did it help or cause new issues?
It might be helpful for you to share what kind of printer you have and what types of materials you commonly print with to make suggestions!
Some materials won’t mind the warmer ambient heat, but others not so much. Filaments in general should be stored in a cool, dry environment. It also might be worth picking up a simple hygrometer/temp sensor to see what the real temps and humidity get up to.
If it keeps the room at a constant temp. and humidity (maybe more important) then why wouldn’t be a good thing.
