I tried z offset I’m using petg. Any ideas?? Ps the breaks were when I lightly pressed on it after it was done to see if those spots were weak or not and they broke way to easily. I don’t know what to do. Okay so I was able to after doing what you all said and this is what I’ve been able to get.
Have you run a temperature tower?
Have you check for clogs in the extruder?
Are you sure you are using settings for Petg?
Is the extruder gear slipping on the stepper?
Exstruder is clear
Default emended 3 cura petg profile
Filiment feeder gear slips but not in a pattern so yeah.
That’s a layer shift.
You should be looking at your belts and how tight they are.
This is not extremely helpful, but should give you some ideas:
