Help! I have the Kywoo Dual
printer and recently in multiple different prints the same flaw keeps appearing and I don’t know why. Any advice out there would be greatly appreciated!
Hi @Dread
I am assuming you are printing these vertically and this artifact is showing up on a vertical surface.
It’s basically ringing, They show up right after a direction change and is basically the head vibrating.
The quickest way to test is to slow the print down, Leave the slice on there as it just changes your PS to 50% and you should see an immediate change.
You definitely assumed correct, sorry. I will try that tonight. Thank you!
anytime, Just post up if you have any issues, we will work through them
