I am wondering if anyone knows the physical/mechanical property differences between the value and the regular PLA.
ie: is one more brittle or stronger or resistance to flex or more stringy …
Hi there
I cannot say as I can give you a 100% technical answer to that question, From experience printing with both, Value generally prints about 10 deg cooler than the standard premium line, I find quality on both is very similar however i did find that you can change the hue on the value brand, go from gloss to matt with a temp change of as little as 5 deg.
Property wise they are both very similar.
jason
That sounds more like a feature than an issue xD
My next print will be from the value pla so ill be excited to see that effect.
