Someone in a discord group I’m part of got one and it’s quite intriguing. I’m starting to play with 0.3 and 0.2mm nozzles for finer prints, but I don’t like the “risk to burn finger tips” in trying to remove a hot nozzle and adding a new one.
Anyone have any other tips or tricks? Is this something 3dprintingcanada.com may consider stocking?
It is a 1/4" socket holder, with the additional block-support. Seems like it braces against the block to keep things square and make sure you’re not torquing it too much (I think?).
I Just use a round ratchet someone gave me and this is the first use if found it worthy of heh. If I was goi g to make a tool it would be that shape but I’d put a ball detent in it and have it slip at the right torque. Maybe ill make one.
It looks jankie in the video. The block holder appears to be a bit of pipe shaped with a socket suck in the middle. There is a torque limiter but it is extra. $42 I am guessing USD? 50$ seems like a lot of money.
Buying the suggested socket adapter (which AFAIK come in sets) is far cheaper than buying and importing the Z-Catch. It’s currently out of stock, I was wondering how much to ship that up to Canada.
Yes. I’d seen them years ago at Princess Auto and thought “When the heck am I ever going to need something like that? I might as well just use a small ratchet.” Well, now I know where it would be handy.
That looks convenient. Do you think it’s shallow enough? The nozzle is about 8.5mm long before the threads start - would want the ratchet to hold the nozzle up high enough that you can screw it in.
That’s what I use. The sockets are indeed too deep for the short nozzles though. You could put something melt proof inside the socket, i just machined mine off
