Belt clamps with grub screws
Hi y’all
I added the rubber dampeners to the NEMA 17s on my printer, but a belt came loose. I cannot get a zip-tie back on the end. I see there is a belt clamp with a grub screw on the 3D Printing Canada store. Does that fit 2 ends of a belt together and the grub screw holds the 2 ends together?
Thanks!
I suppose if it does not clamp 2 ends together I can use it, by sliding it down the belt and tightening the grub screw. I’ll just go buy them and see. You guys are so helpful! :slight_smile:
hi, @myearwood65 Welcome to the forum, I’m glad you found us.
YEs, the intention for those belt clamps is to hold 2 ends of the belt, however, I have never thought to use them just with 1 end, Don’t think it would work as well but in a pinch, I am sure it would work.
https://imgur.com/a/bULBQb5
They work perfectly.
That’s awesome glad they worked for you. Any other issues just let us know.
