BIQU B1 by BigTreeTech - This things neat
The purge line was fine for the print that’s running now after I fiddled with some of the settings. Must have gotten lucky. Thanks for checking GitHub.
Ok here is it. Not really as much there as I though but there’s some helpful stuff there specific to B1’s I’ll post more f I find them again.
Your purge line comes from your slicer are you using Cura to slice your files? the Start Gcode is in there and thats where the positioning comes from but not if the bed is in the wrong place, like it was not homed properly
Thank you Glenn!
Les
There’s been an amazing ‘AHA!’ with my BIQU lately. The Poltergesit that lives inside it must have heard me talking about boxing it up and relegating it to the cold and dark attic. Long story short; along with going back to simpler Cura profiles I’ve started using the Marlin Mode exclusively. A manual level is followed by the BLT and once completed, the file loaded and ‘tuned’ it does another BLT level and then goes to work. I’ve also discovered that the lights really do have a pupose. I thought they were just a nice sales add-on. But they really do tell you where the printer is at in terms of the prep process. It still makes mournful fan noises when starting up, even after loosening the screws to the fan housings, but that fades away after about a minute or so and it runs nice and quiet with very good print results.
I added the commands to my Start g-code for the lights to work like that, Did you do anything like that to make them work?
Hi Glenn,
Nope. I just started using Marlin Mode and it happened. At first I kept scrolling down and turning them off wondering why they were coming on. Then on one print I left them alone and as I watched them change colors along with the temp changes on the screen it dawned on me what they were doing. It’s actually a pretty nice feature.
Les
Oh thats interesting. What colour do you have and whe. Does it change? I used Marlin regularly before this new firmware and haven’t been there since but in mine it was the same. I could just select the colour and that’s what I would have.
Hi Glenn,
Once its gone through the second BLT round after I tell it what to print and ‘tune’ it, the blue light comes on telling me its cold. As the plate and nozzle heat up it changes to almost an indigo which starts to get red as the temp goes up. Once up to temp the light goes to white signaling it’s ready to print. I leave the white light on till after the left-side-purge and the first few brim/raft/skirt lines. That way I know it’s printing evenly all-the-way-around the build area. Then I turn off the light and leave it alone.
Les
That’s great. I just restarted a print that failed and forgot to try it heh. next time, I wonder where that comes from?
Hi Glenn,
I have no idea. But ever since I started using Marlin and figured out the lights and how to do the manual level before the BLT - I use a business card and adjust to where I can feel the nozzle just barely making contact when I slide it around - it’s been doing fine with very nice prints. So it’s gotten a repreive from the cold and dark attic. Now I need to figure out which internal fan is making the noise and why.
Les
The B1 Poltergeist has returned and has decided to no longer Auto Home and do the initial purge line on the bedplate. Otherwise it’s printing nicely using Marlin.
Did something change your start gcode in The slicer? That’s where those instructions come from.
I’ll have to check on the next print. It was working fine last night and saw it was off the plate starting up a new print this morning.
you can open the gcode files in notepad and compare a known good one to what you have now. under the lines that say something like “; BIQU B1 Start G-code”
Thanks! I’m not up on gcodes at all so this is very helpful!
Cool. If you go to
All the codes (or most) are there and you can search each one to see what it does and how it’s used.
I will check it out, thank you!
Dude. I grab mine by the top rail, throw it in the car, use it on jobsites without relevelling.
I don’t know what went wrong with yours, but this is my first machine and it is bullet proof.
Absolutely gotta have bl touch, power through the spring and gender of wire issues.
Ya man it took alot of messing around and adding ABL to get it to be reliable. It is now pretty good however all the fans have been changed. They started to die within 2 weeks and went one by one until all had been changed.
The BIQU Poltergeist has returned. Everything was pretty much working fine except there’s now suddenly no filament when when printing. Extractor was cleaned, Bowden tube replaced, new nozzle, and still nothing comes out even when doing a purge via the printer. When it’s hot I’m able to insert and push a cleaning drill up and down into the nozzle without difficulty, yet still no flow. Seems the PLA is getting blocked somewhere along the line.
