Empty spool weights
This is lifted from ‘So you have run out of …’ thread by (@gondolin).
3D Printing Canada Euro Line Spool: 225g (@Keith )
3D Printing Canada NEAT Line Early 2020 Spool: 240g (@Keith )
3D Printing Canada Standard Line Spool 240 g ( @Keith )
3D Printing Canada Value Line Early 2020 Spool: 230g (@Keith )
3D Printing Canada Value Line Late 2020 Spool: 230g (@Keith )
Amz3d 224g (@mobiobi )
Canadian Maker 328 g (Kitedemon)
Creality 200g Spool: 104g (@Keith)
Dupont Clear 1kg 360g (@Amiro62)
Esun Black 0.5kg 212 g (@Amiro62)
eSun Clear 210 g ( Thanks to @Amiro62)
eSun Black 230 g (@Amiro62)
eSun Clear .5kg 203g (@Amiro62)
eSun Nylon, CF-Pa Spools, Clear w/Bolt together : 220g (@Keith )
Eurekatec (3d printed-laser cut mdf) 242g (@kitedemon )
Geeetech 182 g black (Kitedemon)
Geeetech 233gm ‘cubes pattern’ (@Keith)
Hello3D (rainbow label) 210g (kitedemon)
MG Chemicals Black “Narrow” 1Kg: 239g (@Keith )
MG Chemicals Black “Wide” 1Kg: 250g (@Keith )
MG Chemicals Black 200G: 136g (@Keith )
MG Chemicals Cardboard 1Kg: ~150g (@Keith )
Nefila “Recycled filament” reusable Spool: 130g (@Keith )
Priline 206 g (Kitedemon)
Sakata Clear Spool: 240g (@Keith )
Sakata Grey Spool: 205g (@Keith )
Solutech black spool: 218g (@kitedemon)
SunLu Black 1Kg: ~220g (@Keith )
SunLu Clear “Lightweight” 1Kg: 139g (@Keith )
True Food safe PLA (3dpn) 250g (Kitedemon)
3D Printing Canada Budget Spool: 126g (@lauran)
Hopefully we can keep adding weights. It might help others to figure how much filament is left on a roll. :sunglasses:
3D Printing Canada Standard Line Spool: 240g
3DXTech Black Spools:
3DXTech “200g” Red Spools:
Creality 1KG Spool:
Hello3D Spool:
GeeeTech 1KG Spools “Cubes pattern” : 233g
Materio3D Spool:
Recreus Clear Spool: 240g
Sakata Clear Spool: 253g
Awesome! I’ll just keep adding them !
Now if only I had an accurate scale, I could give you some Geeetech numbers.
ESun Clear .5kg 203g
ESun Black .5kg 212g
(AMZ3D 1kg, 224g…)
I just finished a 15 hour print. I had weighed the part roll of Amz3D and Based on @mobiobi weight figured I had what I needed. I did finish the print with around 35g left. 19g less than I calculated but given scales water absorption and a 100 variables I am not thinking of that seems really reasonable. Thanks gang! That helped I didn’t think there was enough on that spool.
I sorted this alphabetically and added one.
IIID Max PLA+ spool 216g, density of filament 1.24 g/cm3
Thanks @bd43 the form has locked the top so it is no longer editable. I am talking with Keith to figure out something. Stay tuned!
@kitedemon
Alex,
Please just cut and Paste all the data into a new reply with all the updated weights.
I’ll mark it as “Solution” so it’ll quick link to the new post.
If I Make the post, only myself or higher can edit it.
Brand Kind Weight in Grams Submitted
3D Printing Canada Euro Line Spool 225 Keith
3D Printing Canada NEAT Line Early 2020 Spool 240 Keith
3D Printing Canada Standard Line Spool 240 Keith
3D Printing Canada Value Line Early 2020 Spool 230 Keith
3D Printing Canada Value Line Late 2020 Spool 230 Keith
Amz3d N/A 224 mobiobi
Creality 200 gm spools 104 Keith
Dupont Clear 1 kg 360 Amiro62
eSun Black 500 gm 212 Amiro62
eSun Black 230 Amiro62
eSun Clear 500 gm 203 Amiro62
eSun Clear 1 kg 210 Amiro62
eSun Nylon, CF-Pa Spools, Clear Bolt together 220 Keith
Eurekatec Laser Cut with 3d printed core 196 Kitedemon
Filaments ca Canadian Maker Series 328 Kitedemon
Filaments ca True Food Safe PLA 3DPN 250 Kitedemon
Filaments ca EcoTough Clear 215 Kitedemon
Filaments ca Value 210 Kitedemon
FormFutura Apollo X 750 gm 195 Kitedemon
Geeetech Black 182 Kitedemon
Geeetech Cubes Pattern 233 Keith
Hello3D Rainbow Label 210 Kitedemon
IIID Max PLA+ (this is likely common to others) 216 BD43
MG Chemicals Narrow 1 kg 239 Keith
MG Chemicals Wide 1 kg 250 Keith
MG Chemicals Black 200 gm 136 Keith
MG Chemicals Cardboard 1 kg 150 Keith
Nefila “Recycled Filament” Reusable Spool 130 Keith
Priline Black 206 Kitedemon
Prusa by Fillamentum Clear Spool with Core Sleeve 284 Kitedemon
Prusament Spool 191 Dr. Marvin
Sakata Black 240 Keith
Sakata Clear 205 Keith
Solutech Black 218 Kitedemon
SunLu Black 1 kg 220 Keith
SunLu Clear ‘Lightweight’ 139 Keith
Y&S Filament Clear 1 kg 280 Kitedemon
@kitedemon
Thanks Alex!
Tomorrow ill check my prusament spools to add them to this list. Though if you have a spool of prusament you can check the weight yourself online aswell.
Sorry for the delay.
My petg prusament spool weight is 191 grams
I’ll get that in later. @Dr.Marvin is that the hex pattern spool?
I finished a couple of Eurekatec spools this week. There is a lot of variation in the weights, I weighed and averaged the weights and updated the list. Please keep in mind there will be variations in all the measurements but this one is quite large with MDF and printed cores.
I got plastic cores with my Eurekatec filament. They take them back and give you a bit off so think they get all kinds in there
