Ok,
Using Cura, my 5 plus was was drawing a purge line on a 45 degree angle right thru the center of the build surface. I got that figured out. Seems there is some bug in the Marlin Firmware and this is what you get when you call M420. So, I dumped M420 and opted for G29 with an F2 fade height instead. So this is my printer start up file currently.
M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
M220 S100 ;Reset Feedrate
M221 S100 ;Reset Flowrate
G28 ;Home
G29 F2 ;Enable ABL using saved Mesh and Fade Height
G92 E0 ;Reset Extruder
G1 Z2.0 F3000 ;Move Z Axis up
G1 X10 Y20 Z0.28 F5000.0 ;Move to start position
G1 X10 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X11 Y200.0 Z0.28 F5000.0 ;Move to side a little
G1 X11 Y20 Z0.28 F1500.0 E30 ;Draw the second line
So this got ridda the 45 degree purge line across the center of the build surface. But now, calling the G29 code, the BL touch probes the bed in an odd way now. It comes right to the front, just a few mm from the edge, kinda scary, and doesnt probe far enough to the right leaving 20% of the right side of the bed untested front to rear…
So Im thinkin somehow I need to edit where the BL touch probes the bed.
Anyone got any idea how that is completed? Be gentle now… Imma kinda a newbie at this
Cheers!
