Sonic Pad firmware in a bin file not an SWU file
Where can I get firmware for the sonic pad that is in bin format? The SWU format is all I can find and it will not update from a memory stick. Need Bin file format.
Check my other post which is related to the same problem, It has a really good firmware issue fix for the sonic pad.
Stuck on print screen with fix Sonic Pad
