Temp. settings on printer
it doesn,t matter what tempature I set on the printer when I go to print it always changes to 200 for the nozzle and 50 for the bed.
When you make the .GCODE file on your slicer, did you set the temperatures there? Those will override the temperatures that you set on the printer.
Which slicer software are you using?
I’m brand new to 3d printing. I am using cura for slicing but I don’t see where you can set the temperature. Also I am using files downloaded from thingiverse. Thank you for your help
The temperature settings are located under the “Material” category.
