Tried to flash the new firmware on. Copied Ender-5 Pro- Marlin2.0.1 - V1.2.1 - Endstop - Filament - TMC2225.bin to the SD card, removed other files, unplugged the 3D printer, put the card in, plugged in printer and turned it on…wouldn’t flash.
Tried renaming the firmware file to FIrmware.bin, deleted other files on the card (added by the 3d printer: EPROM.dat), unplugged the printer, plugged the card in, and powered the printer back on. Still no luck.
seems like you’re doing everything OK, Did you format the card using 4096 byte size,? looks like the board is not reading the bin file or the firmware is same version as what’s on it. Try flashing an earlier version number and then flashing again with the newer one.
seem to remember reading a bug somewhere you had to call it firmware.abc.bin, if that didn’t work you would have to rename it to firmware.bcd.bin something about different filenames but not firmware.bin or it wouldnt work. trying to find the article in my history.
no the size of the SD should be fine, Just wanted to make sure it wasn’t something like a 128Mb that does not give enough swap space to complete the operation.
The article I was was on TH3D website, they have a note about it having to change the name of the firmware. bin file
Thank you sir. I tried building the code as per the article but I get an error during compile time indicating sdkconfig.h doesn’t exist, and then the build stops.
BTW, just to confirm, I am using an official 32 bit Creality mainboard (with silent motor drivers) which I purchased from 3d printing canada. Does that come with a bootloader? Does it support update by just plugging in the SD card?
