there is an adjustment, you can set it with Baby stepping for a print by print adjustment or if you need to move it at least a certain amount every time you would use the Z offset. You can set this up with an M851 command. To me it looks like the first layer is too close, I think you can quickly move this a bit to help your prints come off much easier. This article on the first layer helps visualize what it’s supposed to look like.
