Summer 2021 Wishlist, What Products do you want to See in Store!
If you look closely at the corners of my bed you can see that I’ve simply printed mine. I had to print them because I bought a piece of Longer L1 glass from 3DPCs clearance pages to try out on my Ender 5Pro. The glass is significantly larger then the 5Pros build surface so a standard clip wouldn’t do it, but building corner clips like this works like a charm. They’re custom fitted to the thickness of the glass, the thickness of the build plate and the distance from the corner of the build plate to the corner of the glass.
I can appreciate that. I don’t currently have anything other than PLA to print with and am not ready to move to another material yet so likely won’t expire this yet. I suppose the point generally remains that I’d be more than happy to pay a few dollars to solve this problem and would be fine if they were plastic clips, as long as they work
I was a little surprised on the zcatch, they do not have one video showing it in use on their website. Looks like the coolest thing since sliced bread but cannot see it in action.
@awalkerca @Glenn @Jason @kitedemon @LEGOManiac @TurkeyOnRye
Here’s where we Stand So far!! Please Up/Down Vote +5, +3,+1
Please mark them as
+5 points = NEED
+3 points = WANT
+1 Point = WOULD-BE-COOL-TO-HAVE
Item: … Current Points:
Ender 5 Pro – Aluminium Bed Supports … 3
Aluminium Extrusions – Cut To Order … 3
Anodized Aluminium Extrusions – 1M Lengths … 1
Colour Changing Filament … 1
More Kapton Tape sizes … 3
Thin Metric Lock Nuts … 3
Long Cap Screws Threaded Full Length … 3
Makerbase UPS Module … 1
Makerbase Robin Wi-Fi 1.0 ESP8266 … 1
Assorted Bolt Kits … 1
3D Maker Kit: Pilers, Screwdriver, De-Burring tool, Nozzle Wrench, … 3
Assorted Hardware, Purple Glue stick
Digital Vernier Calipers … 3
Nozzle Varity Packs … 3
https://3dprintingcanada.com/products/unofficial-e3d-nozzle-fun-pack
Nozzle Removal Tool: ZCatch … 15
Voron CoreXY Kits … 3
Assorted Magnet Sizes … 3
PLA+ 1.75mm 1KG Spools … 5
Finger Ratchets For Nozzles … 5
240x240 Spring Steel Sheet with sanded PEI top layer … 5
Bring Back: 3D Gloop … 6
Siraya Tech Resins … 4
Ender 3 Pro 310mm Kit … 3
Ender 3 Pro 400mm Kit … 3
Ender 3 Dual Extrusion Kits … 6
Spidermaker SpiderSilk Filament … 8
Products Created and Made in Canada … 21
World Peace … 10
Packs of x4 Swiss Clips … 4
From Searches on Webpage
HatchBox Filament … 25
Prusament Filament … 23
Voron (Parts and Kits) … 20
LightWeight PLA Filament … 16
Polymaker PolyTerra PLA … 16
Water Washable Resins … ` 11
Bring Back: RepBox … 9
Bring Back: eSun ABS … 8
Orbiter Direct Drive Extruder … 8
ExoSlide Rail System … 7
Colorfabb PLA … 7
BiMetal Heat Brake/Break … 5
Garolite Build Surface … 5
Bamboo Filament … 4
BIQU H2 Extruder … 4
+5
+5
+3
+5
Assorted Nozzle Packs - I must admit I don’t really know one nozzle type from another. Also, I think, rather than an assortment pack, I’d like a bulk pack of a given size.
+5
+3
+3
Galactic Peace so may be they’ll finally put StarWars out of it’s misery.
More kapton tape sizes … 3
+1
Long cap screws threaded full length … 3
+5
240x240 spring steel sheet with sanded PEI top layer … 5
(If you find it ill buy it jut im unsure of the communities interest in it. I just know with my prusa mini, the satin sheet is worth its weight in gold as it prints prettymuch all materials with no extra prep on my part.)
Prusament filament
+3 ( i dont need more at this time, but having closer access to their filament would be awesome, so long as its cheaper than buying prusament from amazon)
Fast stable core xy Voron or similar +3
Bolt kits +5
Magnets +5
Prusament +3
Hatchbox +3
And CANADIAN +5
Plexiglass or acrylic sheets to build an ikea lack enclosure.
Honestly done up as a kit wouldnt be a bad idea either.
@Keith
Will you post an update if any of these suggestions end up in the store?
Metric drill bits. Particularily 4mm, 2mm, 1.5mm.
I only need 1 of each, but its a bit tricky finding that elsewhere.
I can get Keith to update this thread when items are ordered. That way you can see ahead of time what we are adding.
Thanks Jason. Much appriciated :slight_smile:
Great news we have some Products Samples ordered and will be sent to us for testing soon (Soon-ish)
/Giddy
well /Gitty Too (Very happy while Slight nervousness )
Good day you guys, great news for this post! As per the Summer 2021 Wishlist we have Sunon MagLev Fans on the way soon to the Store Front!!
Try Clicking: Search results for “Search: 10 results found for “Sunon”” - 3D Printing Canada
it will give you Products like:
3D Printing Canada
3D Printing Canada - SUNON Silent Cooling Fan 40x40x10 24V 4010 40mm
Official Sunon Silent Cooling Fan 40x40x10 24V 4010 40mm This fan is used to cool the fins of the heat sink, Control Boards on 24V printers Dimensions: 40x40x10mm Sunon MagLev 4010 axial fan
Price: CAD 14.95
That’s great. do they have a radial fan you could get too? one of the ones I installed is starting to get noisy after a week of silence. So If I keep having to throw fans on I may as well get better ones.
We have added:
  • some VORON 2.4 and VORON 1.8 COmpatible parts, more on the way!!
  • Liqcreate Resins! Impact, Composite-X, Flexible-X, Hazard Glow, Premium Model, Premium Tough, Wax Castable
  • We have a few Nozzle removal tools coming for testing, PLease keep eyes out for them
  • Official Creality Ender 3 CR-10 High Temperature Full Hotend - DragonFly Style
  • Official Creality Ender-6 High Speed Full Hotend - Dragon Style
  • Official Creality CR-6 SE, CR-6 MAX, CR-10 Z2, CR-10 Smart Hotend Kit 24V - Stock replacement
Why do I only ever see stuff like this 2 hours after my order ships?
I’ve added it to my wishlist.
Sorry Lego, i’d have posted it sooner. However I was busy in web forum and warranty requests with Needy Customers.
Which printers would these be usable for? I’d love to be able to quiet down my CR10s Pro v2 which sits on the desk beside me all day long.
Hello Moose,
for CR-10S Pro.
24V
Hotend = 40x40x10mm
Part cooling = 4020 Blower
Control Box: 40x40x20mm + 4020 Blower
12V: Meanwell PSU 40x40x20mm
